This Is a simple short write up on replacing the rear camera on escalade esv. My camera system started displaying service rear vision System. I ordered a 60$ oem camera on ebay. The easiezy and 30 minute swap is through the rear under the applique where the rear camera is located. First u need a flat head screwdriver and 10inch needle nose pliers min. And some sealant or plastic glue.
My process I popped off the rear camera with a screwdriver and the camera broke but oh well it was broken anyway. Then I pulled out the 12 inches of cables thru the camera hole. I then used my needle nose pliers and grabbed the connector thru the camera hole and I yanked on it until the clips break off of the cable enough to pull more cable out. Once more cable feeds out you can disconnect the connector and change out your camera and finish your install with a little glue to put ur camera back on.
Word of advice I tried removing the rear panel from inside but it doesnt help at all with camera replacement. This isa very quick job. I wrote this to save others time.
My best guess is the original camera is poorly sealed and the applique isnt water tight so with any car wash etc water seeps into the camera and you have problems with the system. Good luck everyone I hope this helps someone in the future. Sry no pics because it was raining today.
