i have a 2007 cts i replaced the steering column from wrecking yard it was same model and year as mine. Non of the steering wheel control or horn works. Would appreciate any help. Thanks
2005 Base CTS work at Pullen solenoids Glass Factory for 36 and a half years
Did you disconnect the battery when you did it? If not I would disconnect it for 20 or 30 minutes and try reconnecting it. You might also recheck all the plugs that you're plugged in.
Roy
2007 CTS 3.6 >131k miles
I would suspect a plug or two was left unplugged, as @TA Coupe said, or otherwise has a bad connection. It is also possible that the horn and steering wheel controls didn't work when the donor car went to the boneyard.
I think when i bought the steering column from wreking yard i didn't know that if i tuned the steering wheel over 3 or 4 turns that those wires would break. I don't know if I did it or the wreking yard. But everything was working with the old steering column. I broke a wire on the old one so waiting on one from wrecking yard now.
