1 - 11 of 11 Posts
2007 6 speed manual tarnished platinum
I've done it what do you want to know. Just the basics are undo the shifter, drop the exhaust and driveshaft, undo the steering shaft at the rack, take out the back 2 engine cradle bolts and loosen the front 2 , undo the trans support and slowly lower the rear of the engine cradle 2 inches. Then take out all the housing bolts external torx e14. Rotate the trans clockwise and its out. Take the heater hoses loose at the firewall too before you lower anything, the factory shop manual doesn't mention that. Get a ratcheting e14 wrench too. Lots of extensions and at least 6 jack stands. Huge pain, especially the heater hose pipe assembly that must come off the block to get a bolt out, starter comes off too. You really can't resurface the dual mass flywheel and shouldn't its probably worn out so figure a new flywheel, mine was bad too.
2014 CTS
Do you know if the procedure is the same for the 2006?
Thanks, Les
I just had a new clutch flywheel and rear end as well as mater and slave cylinder put I'm I drove about 20 miles and car got stuck In 6th gear any ideal why it could be ? I'm getting another transmision tomorrow buy don't believe I need one om a carpenter by far no mechanic lol but I'm definitely learning they should have put boat behind cadilac symbol bust out another thousand lol sorry just had to put that out there any help would be appreciated thanks for your time
1 - 11 of 11 Posts
