P0222 Throttle/ pedal/ position sensor/ switch B circuit low
P2119 Throttle actuator / Control/ Throttle body range/ Performance.
The throttle plate doesn't want to move when the car is running. The car shakes vigorously and you can smell gas coming out of the exhaust. I am wanting to know if anyone knows how to tell if its the throttle body itself of a sensor or switch?
Welcome to CF !!! Here's a DTC definition site you can use to define and post code meanings.
TPS ? (Throttle Position Sensor)
I know what the codes are for but they have various fixes and i was just wondering if anyone had any advice before i assume its the throttle body.
P 0222 - TPS _ Throttle Position Sensor - attaches to the throttlebody.
2003 Deville Base
Welcome to the forums! More often that not, if you post the definitions with the codes you will get more specific advice. There are several thousand DTC's and no one has them memorized.
