41 - 60 of 89 Posts
yea i tried that too.. took the air out all the way almost, re-armed the system, did tire 1, tire 2, and bam pumped it up all the way and nada on tire3.. just to see if the 4 tire would work, and just enough, took 20seconds to make the horn sound..
2012 Escalade, 2014 SRX
Discussion Starter #42
It does not work for all trucks for some reason, I have had several that needed the reset tool
can i purchase this tool? Is it only just this one tire(sensor) that has the issue since the other 3 work? Would it help if I try another sensor on this tire?
2009 escalade hybrid
I pulled the trigger and replaced my alenzas with at least 1/4 life in it for a set of 4 brand new ones from my local firestone. checked dic and all read 36 psi as specified by me. anyways, since I was traveling west with full cargo(hence the need for new tires), I inflated the rears to 40 psi. when I checked the dic, it read the opposite from what is real. the 40 is upfront and the 36 rears. time to reset these tpms. will probably do it when I get back since I prefer my own air compressor tool vs the gas station ones. my point was, you would think these tire shops would know how to reprogram those sensors:(
2007 Cadillac Escalade
OweSome OweSome OweSome
I have to say THANK YOU for people like you
All I had to do is read hcvone helpful guide and I solved my problems.
Once your problem now my problem then someelse problem.
I'M proud to be a part of this forum.
I just did my 2011. was fairly simple. no special tool needed. Just do it in order, because I did it out of order, and got them all mixed up. then I did it over. use the key fob, and then excite the sensor by adding air or removing air.
2007 Escalade, 2005 CTS
Ok. Is there a trick to this or what? I did this before, and it took 2 or 3 times, tonight i spent almost 2 hours trying to do this. Pumped them all up to 40+, deflated them all to almost flat tried putting the air in, the furthest i got was just the first one done, and that was only like 3 times.
Figured it out. hcvone's instructions are correct, but some people who were having bad luck may have over looked in the instructions. The last time I did it a few months ago, I let air out UNTIL i heard the horn, and it worked. Last night i tried for almost 2.5 hours and it was not working. The problem was, your supposed to let air out, or put air in for 5 to 10 seconds, then stop, and wait for the horn, then move on to the next. This took 2 times and now its re-learned.
Discussion Starter #50
Some sensors react quicker than others, glad you got it to work. :)
2011 Escalade Premium Edition
Yes the process can be finicky. What I also learned from doing this multiple times with a 2009 SRX was to drive the car with the new sensors over 30mph to be sure they are activated. Then when you do the relearn make sure the old sensors/tires are no where near the car because they can cause interference.
2007 ESV, 2005 CTS
Are the TPMS sensors (the part within the wheel) the same for all years? Our 07 ESV's wheels aren't in great shape and I'm planning to buy new ones. I want to get new TPMS sensors in the process, but want to make sure they'll still talk to our 07 cluster with no issues.
Discussion Starter #54
The early 07' had aluminum valve stems and they were a lot of trouble, but yes you can get the latest pressure sensors and they will work with your truck, no problems at all, best prices we see are on e-bay, we get dozens thru them
2008 STS Sedan
I tried this procedure on my 2008 STS and after the first tire on the driver's side worked, none of the other tires worked. Now, the system is showing no tire pressure in the other tires, just the one on the driver's side. Can anyone help with this issues? Should I take it to the dealer at this point?
Discussion Starter #57
Thanks! I just grabbed a set. I presume the newer style is lighter and won't require as much weight to balance.
Slightly lighter
I do not know the process for the STS, it should say something in the owners manual, I am looking for info but didn't find anything, try posting in the STS section
sts4 2007
i have tried this over and over again and i cant seem to get the honk on the first tire...I put the parking break on, hit the access button,hit lock and then unlock and then held both down until i heard the double beep. I let air outof front left tire for 5 seconds and waited but never heard the honk.
I also tried another way.I put the parking break on , held the access down until car turned on(engine didnt start just turned everything on the dashboard on), hit lock and unlock and then held both down. the two beeps never came that way from the key fib.
Any ideas???
Discussion Starter #59
Any ideas???
I have had many of these trucks, and two of the ones I had, (07', 09') I could not get to work with this method, all my other trucks worked fine this way.
2006 CTS, 2007 Escalade
Bought new rims yesterday, (platinum replicas matte black) found this thread under the new sticky that mrholland (i think) made, did what hcvone described to do, took me 3 times bout 10min total...worked great!! Thank you both!!
41 - 60 of 89 Posts
