2006 STS4 1sg
Hi all, I have a 2006 sts and I have an issue with the radio changing stations, volume, and switching CDs. Seems like it happens more when the heated wheel is on. Also the light on the softkey button all the way to the left on the wheel is out if that matters. I'm at a loss to what to do here. I can't afford to dump a ton into this thing but I see you guys are extremely knowledgable on here and Id appreciate any thoughts/ ideas. Thanks
Premium Member
Sounds like the clock spring ribbon cable that connects everything to the wheel has rubbed through the insulation. It can only get worse.
2006 STS4 1sg
Are those expensive? I've taken steering wheels off before. I'm assuming this isn't different right?
Premium Member
Because you'll encounter the steering wheel airbag you'll need detailed service information. Your best bet would probably be WWW.ALLDATADIY.COM.
Nothing is cheap when you work on a Cadillac.
