2006 STS-4
The right headlight washer on my 2006 Cadillac STS-4 is stuck, sticking out about 2 inches from the front of the car. It happened about a month ago. I live in Wisconsin, and was using my washer fluid, and noticed the pressure wasnt as good as normal. When I looked at my car I noticed the headlight washer was stuck out and not returning back into the car. I took it to the Cadillac dealership and when I used the washer fluid it the headlight washer would pop out its normal 3 inches but not spray fluid, as it was leaking under the car. Then it would return only an inch, remaining stuck out. I would have had the dealership fix it but they said it would cost $150 just to open the hood. Does anyone have any experience with the issue, or is this something I could take to a standard mechanic (to avoid $150 charge) to have fixed? My car just came off warranty and I have only ever used to Cadillac dealership for repairs, so am hesitant to use a standard shop or mechanic.
Thanks!
08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
The reason they want $150 just to look at it is because they have to take the whole front fascia off even to get to it (or change a headlight for that matter). They are probably estimating about 1.5 hours to disassemble, have a brief look and put it all together again. You can take it elsewhere and maybe save a few bucks, but it's the same amount of work regardless of where you go. Generally, shops will charge a minimum 1 hour for most jobs.
You need either a warranty or thick wallet whenever these cars need service.
05 STS4
I deactivated mine, other than wetting the front end so road salt sticks to it and wasting more washer fuild they serve ZERO purpose.
2006 STS 1SG & 2007 STS 1SE
I think the washers do help whem conditions warrant. However, I don't like them running automatically whenever the headlights are on. They ought to be on a separate switch.
The washer solvent use is not excessive at all to me. Opinions vary.
The high pressure washers are very necessary, IMHO, on vehicles with HID lighting. HID lights do not put out heat like incandescent headlights, so, as I have experienced over the past few years driving a car with HID lights without washers (CTS with aftermarket HID, hence no washers) and mySTS with HID and washers, during heavy snow, slush and icy conditions, they have been a real benefit/feature of the HID option. Thankfully, the STS has a humongous reservoir because, IMHO again, it uses serious amounts of the do-it fluid, and with the cost reaching that of gasoline, for the alleged good stuff, that can get expensive in the winter around Chicago!
+1 on the switch idea. When possible, while stopped at a light, I'll occasionally make the effort to turn off the headlights, then wash the windshield.
