1 - 2 of 2 Posts
2006 ESCALADE
hello,
on my 06 Esc, the remotes are not working. They appear to be dead. I point the remote to my truck from 10ft away
and nothing happens. I then get within 2 inches of the drv door key hole and click and nothing happens.
I have 2 remotes.
1. I checked the battery in each remote and it is 2.99V so batter is good in each remote.
2. I then checked the fusebox on the drv side dash and fuses look good. I checked the fuse
labeled "DDM" (Drv Door Module) and "LOCKS" and they are ok.
Did not check relays... maybe relays have gone bad?
3. I also disconnected the NEG term of the battery and reconnected and still not response from the locking mechanism via the remote.
4. From sitting inside the truck, all locks work fine by pressing the drv side LOCK/UNLOCK button.
5. I do not think it is the remotes ... for 2 remotes to not work all of a sudden is not likely.
6. What else should I check?
thank you
2004 ESV
In this thread;
The OP pulled the Lock and Unlock relays from the instrument panel fuse box for a few hours
1 - 2 of 2 Posts
