Need advice.
Isolated injector on #4 cylinder as a potential problem and replaced the injector with a slight improvement at idle but still random misfire. Had a guy look at it who has sold used cadillacs for 30+ years and he kept saying 'electrical problem' but wouldn't provide any real ideas. Any ideas would be helpful.
Looking for advice on what else could be causing the problem.
- New coils and plugs, 3000 miles ago.
- New Water pump,
- New alternator,
- New power steering pump.
- New purge valve (3 weeks ago) - checked and no issues
- 130,000 miles
- Engine started running rich while driving ( local 30 MPH)
- Only code is P0300
- engine coolant temperature sensor - no issues
- MAF sensor - no issues
- MAP Sensor at idle is showing 2.5volts and should only show 1 volt. The sensor was swapped out and the new one had the same issue
- above 2000 rpm the problem of running rich goes away
- O2 sensors swapped out for check - no issues
- Mechanic has checked all sensors, checked all injectors, checked all plugs, looked at wires controlling individual injectors, can not determine what is causing the engine to run excessively rich
