I know this is an old thread but I was having the exact same problem as others on the standard CTS thread.
I thought I would share my results (fix) here as well.
I replaced all of my brake lines, due to rust and had the same problem of light brake dragging. Bled brakes more times than I can count. Replaced front calipers, rotors and pads. Replaced all brake pad hardware (pins and spring plates). Pulled abs fuse...... Nothing worked.
Finally replaced brake booster. FIXED! It looks like it was hanging up internally and not returning all the way. There is evidence of an old master cylinder leak down the front of the brake booster.
Now I am debating putting the old front calipers on back of the car.
I would have never thought brake booster for this kind of failure.......
I hope this helps someone else.
CTS-V
Thanks butkol, sharing this type of information can save others dealing with a similar issue a ton of time and $!
