I have a 2006 Cadillac CTS and I’ve been experiencing a clunk in my steering when turning. It seems like the steering clunks at lower speeds as I don’t hear anything at higher speeds. I just replaced both outer tie rods because I thought that was causing the clunk but i still hear the clunk. Does anyone have a similar problem or what they did to fix it??
2007 CTS 3.6 >136k miles
Hard to tell without seeing it in person but several possibilities come to mind...sway bar links, ball joints, rack & pinion, etc. Pretty much anything that moves while turning. I would start with an accurate diagnosis. Otherwise lots of parts may be replaced unnecessarily.
Thanks for the reply. My buddy thought maybe the sway bar links after taking it for a ride so I’ll definitely have to take another look.
Personally I would just go ahead and replace them if they are original. Mine were toast at 90k and probably should have been replaced long before that.
Just a suggestion...do not get the MOOG links or any others with grease fittings! This feature is great in concept but the tight space makes greasing them nearly impossible (I need a straight coupler for the top zerk and a 90 degree coupler for the bottom). I much prefer the disposable ones that last 60 or 70k miles.
Thank you for the information it probably is time for them to get replaced considering I have 84k miles which I’m going to assume have not been replaced yet
2003 Cadillac CTS
Yep, links. Thankfully they are cheap and easy, just like m...
...Nvm that was to be too easy.
Sent from Earth II using Tapatalk V
2003 Cadillac CTS
Watch this video. It'll show you how to diagnose. It's super easy. Always good to know vs guessing...
