2005 V
Hello, new to the site. I have a question. I have a 2005 Cts-V that had been making a clicking noise from the rear end under load and it sounded dead on like a failing CV joint. So I ripped out the prop (drive) shaft and found that the CV joint that couples to the rear end had excess play in it. I took the joint apart and found that it fried a ball and wore a nice groove where that ball rests due to a failed seal and loss of grease. Anyway, that CV joint has failed. I was able to pull the whole assembly off of the shaft w/o issue.
The question: Has anyone successfully found and replaced that CV joint or am I stuck to buying a whole new shaft? Thanks
2005 V
Discussion Starter · #2 ·
2005 V Drive shaft issues
Hello, new to the site and I have a short story and a question. My 2005 V began making a clicking noise from the rear end when under load. So I ripped the drive shaft out and found excessive play in the CV joint that couples the driveshaft to the rear end. I remove the CV joint from the shaft and found that a seal failed and spit all the grease out. CV joint is ruined.
Question: Has anyone actually found a replacement CV joint only or do I have to replace the entire drive shaft? Because so far, that joint is very hard to find. Pics below. Thanks!
Auto part Wheel Automotive wheel system Brake Rim
Auto part Wheel Rotor Flange Machine
· Administrator
'05 CTS-V
Re: 2005 V Drive shaft issues
I've seen mention on another forum that possibly one could scavenge a CV from a Touareg (VW SUV) driveshaft. Not much information available as to where that suggestion came from or why, but if it works it would certainly be a nice option! The driveshafts seem to go pretty cheaply on Ebay.
