1 - 8 of 8 Posts
Sister's Cadillac engine is toast. Some how, some way she blew it due to lack of oil. I don't understand how you run your engine dry but alas.... Anyway, Replacement engine purchased.
Question is, anyone done simple engine swap before? Method for pulling? replacing? Guides? Details? Pics? Gotchas'?
Been searching around the net and haven't been able to come up with much usable information. First GM vehicle I've messed with, I will shyly admit to being a Ford guy.
2006 CTS
First, the 3.6 in the year you are talking about does have some issues with oil consumption. I'm not sure about the STS, but my CTS doesn't have a low oil warning. I have removed and rebuilt my 2.8 2006 CTS motor. The engine is basically the same externally as the 3.6. It was easier for me to drop the engine out the bottom with the sub-frame than try to hoist it out of the top. You might want to check on the Seville/STS side of the forum. They might have other ideas.
I managed the swap. It was extremely easy. Pulled it from the top. Her oil pan does have an oil level sensor, the new one did not. so i swapped the pans. Other than that the swap was very simple.
07' CTS-V | 07' Lux 3.6 Volant-Borla-Vsways | 08' CTS 3.6 DI Performance
So if the new oil pan has an oil level sensor and the old one doesn't where in the wiring harness does it plug in?
Are you using your original harness or a different one?
2014 CTS 3.6 Premium, 1999 Corvette,370 RWHP & other mods
You got the wrong end of the stick. Original engine had the oil level sensor. By swapping pans, the new engine has the sensor.
Bill
Bill
Woops so I read it backwards :)
i have a 2005 sts 3.6 v6 i put a srx engine in and want to know how to swap engine oil pan without taking motor apart
i have a 2005 sts 3.6 v6 i put a srx engine in and want to know how to swap engine oil pan without taking motor apart . please help
1 - 8 of 8 Posts
