21 - 23 of 23 Posts
2007 CTS 3.6 >140k miles
Is it possible that a valve or valve seat has sufficient buildup to prevent it from seating? If so it may be worth removing valves for cyl 3 and 6 to explore.
If valves are good, the only other possibility is the rings. Hopefully that is not the problem.
One more thing. If the rings are not sealing but otherwise intact, you may get lucky and solve the compression problem with a piston soak. It may be worth trying this before removing the heads and digging deeper.
21 - 23 of 23 Posts
