1 - 19 of 19 Posts
2005 Escalade ESV
after reading sticky and doing advanced search
I could not find a post on how to reset TPMS
I found a post on how to reset 2007 and newer
but not for 2005
thanks in advance
2005 Cadillac Escalade (sold)
easiest way is to have a programmer.... discount tire co. has them and they will do it for free.... but if you dont, u go to your tire settings.. switch to the one u want to program, go to the correct corresponding tire (LF, RF, LR, RR) and let out air from the tire until you hear the horn honk twice, i believe... then follow the steps again to do the other tires
I'm sorry but I think I might be forgetting some steps... As soon ad I find out for sure I will post it ( gotta search my old posts)
2004 Cadillac Escalade ESV
This is straight out of the manual for an 04
Each TPM sensor has a unique identification code. Any
time you rotate your vehicle’s tires or replace one or
more of the TPM sensors, the identification codes
will need to be matched to the new tire/wheel position.
Each tire/wheel position is matched to a sensor, by
increasing or decreasing the tire’s air pressure.
The sensors are matched to the tire/wheel positions in
the following order: left front (LF); right front (RF);
right rear (RR) and left rear (LR).
You will have one minute to match the first tire/wheel
position, and five minutes overall to match all four
tire/wheel positions. If it takes longer than one minute,
to match the first tire and wheel, or more than five
minutes to match all four tire and wheel positions the
matching process stops and you will need to start over.
The TPM sensor matching process is outlined below:
1. Set the Parking brake.
2. Turn the ignition switch to RUN with the engine off.
3. Turn the exterior lamp switch from “Off” to “On” four
times within 3 seconds. A double horn chirp will
sound and the TPM low tire warning light will begin
to flash. The double horn chirp and flashing
TPM warning light indicate that the TPM matching
process has started. The TPM warning light
should continue flashing throughout the matching
procedure. The SERVICE TIRE MONITOR
message will be displayed on the Driver Information
Center (DIC).
4. Start with the left (driver’s side) front tire.
5. Remove the valve cap from the valve cap stem.
Activate the TPM sensor by increasing or
decreasing the tire’s air pressure for 10 seconds,
then stop and listen for a single horn chirp.
The single horn chirp should sound within 15
seconds, confirming that the sensor identification
code has been matched to this tire and wheel
position. If you do not hear the confirming single
horn chirp, you will need to start over with step
number one. To let air-pressure out of a tire you can
use the pointy end of the valve cap, a pencil-style
air pressure gage or a key.
6. Proceed to the right (passenger’s side) front tire,
and repeat the procedure in step 5.
7. Proceed to the right (passenger’s side) rear tire,
8. Proceed to the left (driver’s side) rear tire, and
9. After hearing the confirming horn chirp for the left
rear tire, check to see if the TPM warning light is
still flashing. If yes, turn the ignition switch to OFF.
10. Set all four tires to the recommended air pressure
level as indicated on the Certification/Tire label or
the Tire and Loading Information label.
11. Put the valve caps back on the valve stems
The spare tire does not have a TPM sensor. If you
replace one of the road tires with the spare, the CHECK
TIRE PRESSURE message will be displayed on the
DIC screen. This message should go off once you
re-install the road tire containing the TPM sensor. The
SERVICE TIRE MONITOR message is displayed
when the TPM system is malfunctioning. One or more
missing or inoperable TPM sensors will cause the
service tire monitor message
Will the 2005 Escalade recognize the TPMS sensors on the 22's (I have a set from the newer Escalades 2007 +)
08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
JCastro1085 said:
Everytime I start my truck I get the service tire pressure message on the dash, how can I disable it?
cannot be disabled, only fixed
Can you scroll through different information on the Escalades DIC? If so, hitting the scroll up or down button should return it to the normal display.
I start the truck and receive the message Service Tire Monitor, probably because I have the 22's on my truck (it's an 05) I was just curious if I could disable this feature, it gets annoying to have to push the button every time I get in my truck
your gonna have to get the sensors put in the wheels
From reply #5: > This is straight out of the manual for an 04 < Can any one please help with the instructions for an 05?
Can anyone please help me find the instructions for a 2005 Deville sedan? Page 5-69 in that manual states "Anytime you replace one or more tires or rotate your tires, the TPM system will need to be reset. A special tool is needed to reset the sensor identification codes. See your dealer for service."
Premium Member
2004 Escalade 6.0
This is the Escalade group. You may want to try the Deville group.
09 cadillac cts4 09 yukon Denali
Tool is $8 from eBay and Walmart. Or you can use a magnet. Just Google there's videos on how to do this
1 - 19 of 19 Posts
