Discussion Starter #1 (Edited by Moderator)
I'm currently looking at used 2005 ESV, and after starting it, it idled rough for about a minute. The man selling it said it was a computer feature so the car and heat/A/C would get to optimal temperatures before driving the car. The seller owns his own autobody, and is restoring cars, but I wanted to see if that was a feature or if the model had some problems.
I’m currently looking at a 2005 ESV, and when we started it up, it idled rough for about a minute. It was around 60 degrees out. The owner said it’s a computer feature so the car/engine/heater can reach optimal temperature before driving. Is this a thing?
Welcome to CF !!! Your identical posts have been merged into the correct ESV forum.
A correctly maintained/running engine will NOT "run rough" during the initial fast idle sequence.
The ESV I’m looking at has 80k on the odometer and was owned by an older woman. Could I be mistaking the fast idle cycle for it sounding rough?
2005 Cadillac Escalade ESC AWD
agree with above posts, at operating temperature engine should idle around 500 rpm, and at cold start on a winter day should be around 1000 rpm. Maybe sometimes there is a slight vibration but that usually goes away within 10-20 seconds. Would definitely check the history on engine oil changes.
