1 - 10 of 10 Posts
· Premium Member
2004 Escalade 6.0
Your alternator might be trying to keep a dying battery charged. A lot of auto parts stores will do a free battery load test and charging system test.
· Premium Member
2004 Escalade 6.0
Why do you need to reply the same as me? A bad battery in almost always caused by 1 or more cells being dead. You cannot change cells in Automotive batteries.
2003 Escalade
Did you ever think maybe it was to confirm to the op by giving a second opinion?
Gees chill out
I know you can't change the cells in automotive batteries no need to be obvious about it
· Premium Member
2004 Escalade 6.0
I got a PM saying you are just trying to get to 10,000 posts. LOL Your 2nd opinion was obvious...
2003 Escalade
At the rate your going who knows maybe you are too
I ask you this have you done any step by step how-to threads???
So I get 10,000 posts why does it matter to you??
You don't get it do you?
I am a more active member on here(4 years and counting)and it's a free and OPEN forum so making attacks and laughing at others posts or just trying to be funny really makes you look bad as this forum is seen around the world
Like i said earlier chill out
· Premium Member
2004 Escalade 6.0
Just keep patting yourself on the back and keep up the useless replies to boost your numbers. We understand...
05 Escalade
If it is not a battery problem, then the voltage regulator is going out in your alternator. It regulates the amount of voltage that goes to all of your appliances. Our alternators ususally last around 100-120k miles, but somehow mine got about 200k before having issues. A new alternator will run you 140-200$ and you can easily do it yourself. Barely loosen the serpentine belt, remove the bolt that holds the alternator on, take it out, put the new one in place, put the bolt and belt back on, tighten the bolt and belt and bam you are good. Unplug battery before doing any electrical work on your vehicles. I am about to do mine here when I get the money together. Also I believe the ESV uses the 160 amp alternator versus the 145 on the base models, I could be mistaken though. Make sure you get the right alternator.
1 - 10 of 10 Posts
