1 - 20 of 20 Posts
2005 DTS
I have an intermittent problem with my transmission. When I put it in drive, it really clunks hard, and then shifts real hard and jerky. When this happens, the cruise control will not engage. Other days, it shifts just fine. Even can change on the same trip. Can anyone help with advice?Thanks!
the FIRST step - ALWAYS - is to check for codes -
2005 DTS
Here are the codes I got:
DTC B0429 Temperature Control #3 Rear Circuit Range/Performance
DTC U1000 Class 2 Communication Malfunction
I don't know if these 2 have anything to do with the transmission. Coming home from work it was real jerky. Stopped at the store, the rest of the way home it was fine...
Thanks in advance for any advice.
Whoops I forgot to give the full prefix.
IPM B0429
RFA U1000
IPM B0429
RFA U1000
no -
next check the motor mount -
the front mount is notorious for failing -
ant that allows the motor to flop around -
2005 DTS
Never, but I will if you think it will help. It has 67,000 miles on it, and the display says I have 54% transmission fluid life left.
Wouldn't that cause it to happen all the time? And the cruise control not working when it is in its jerky mode? Then it will shift smooth again, and the cruise control will work fine.
98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
I personally try to change transmission fluid max 60,000 normally 45,000. Transmission fluid takes a lot of abuse so changing it beats changing transmissions
You could have a sticking solenoid or valve in the valve body, intermittently acting up
2005 DTS
Discussion Starter #8
If it is a solenoid or valve, any idea on the cost? I have been recommended to an Aamco shop, or should I stick with the dealership here in town? Thanks.
Usually, if a solenoid or electrical fault takes place, there's going to be a code. Has the car been sitting a long time? Has the battery been recently replaced?
2005 DTS
Discussion Starter #10
It's my daily driver, and I have replaced the battery but that was 8 months ago. I may have had a code, but erased it before I knew what I was doing. It should show up again, right? Thanks!
if the fluid is red - like cherry KoolAid -
and doesn't smell "burned" or stink -
changing the trans fluid is a waste of time and money -
and will NOT "fix" anything -
aamco - and other "chain" trans shops -
are the LAST place I would take my car -
find a local - independently-owned shop -
update your profile to include your location -
there might be a member close to you with a recommendation -
2005 DTS
Discussion Starter #13
After 2 days of driving fine, my problem cropped up today on my way home. And I have a new code.
DTC IRC U1016 Loss of Communications with PCM. This sounds more serious. Anyone have any ideas? I supposed to get my tranny fluid change Friday. Thanks in advance!
"U" codes come and go often -
and are usually a simple - one time computer glitch -
I would simply clear the code - and not worry about -
UNLESS the same "U" code appears regularly -
waste of money -
2005 DTS
Discussion Starter #15
I took my DTS into a transmission shop today. He was able to pull a code that did not show up when I pulled codes viathe dash. He used his fancy computer and up came this code: P0502 Vehicle Speed Sensor (VSS) Circuit Low Input. Could this be the source of all my shifting trouble? Along with the U1016 loss of communication with the PCM? I am having this sensor replaced and wiring checked next week. Any advice, I thank you all in advance!!!
The VSS has a big effect on transmission operation - it also drives the speedometer readout via the PCM and DIC. Does your speedo work properly ?
The VSS is on top of the right transmission output shaft housing - about a foot in front of a passenger's toes.
2005 DTS
Discussion Starter #17
Yes, the speedo has worked just fine. Is the VSS hard to get to? The shop told me if I have to replace any solenoids, I am looking at 2K + because you have to drop the transmission to get to them. True? Thanks for your time!
Since your code point to pcm wiring you may want to start there.. If the VSS was bad it should throw a code and can be changed in the car(not easily as it's tight).
I seem to remember connection issues at pcm solved by cleaning or even jjst disconnecting and reconnecting.
2005 DTS
Discussion Starter #19
To close out this thread, It seems it was the VSS and the wire connector. I have not had that hard shifting issue for over 3 months now. It did shift a little strange the first month or so, but seems to have cleared up. Someone mentioned the battery being disconnected? And these cars "learn" how you drive, etc?
1 - 20 of 20 Posts
