2001 Eldorado 2008 DTS 2005 XLR 95 Eldo'11CTS-V,'66 corvair.'03 deville,'00 deville
Re: 2005 cadillac deville passenger side hot air passenger side
No passenger hot air?
Passenger side hot air only?
Passenger hot air with A/C?
· Master of the Dark Art of Diagnostics
boy - you sure don't make it easy to help you -
are we to assume the passenger side only delivers hot air - regardless of the temp selected?
if YES - the #2 - PASSENGER SIDE MIX DOOR ACTUATOR is probably faulty -
to verify this - check for DTC's - Diagnostic Trouble Codes -
if you don't know how - go here -
http://www.cadillacforums.com/forum...ldorado-forum/138258-how-pull-codes-dtcs.html
post any codes you have -
ALONG WITH THEIR DEFINITIONS -
include whether they are C-Current or H-History -
for code definitions - go here -
http://www.cadillacfaq.com/faq/answers/dtccode.html
here is a how-to video -
https://www.youtube.com/watch?v=0PQhWmlbG_A
if my suspicions are correct -
you will probably have a B0419 code or a B0423 code -
if YES - you need to replace the actuator -
located to the left of the glove box -
