2005 DeVille
Hello all I have a 2005 base deville with 198K on it the front end has a growley rumble
and vibration too
it I have replace the wheel bearing with timkin bearings and rotated the tires
and it still has the noise
I think it still has the original axle shafts could they be worn out and making the noise
and vibration the shafts are dry on the outside and the boots are good
Thanks for any insight Brent
2005 DeVille
engine speed does not seem to effect it but speed of the car seems too change the pitch
but moving the steering wheel will change the sound makes it quieter thats why I thought it was the
cheap wheel bearings I put on it
makes it quieter
I thought you said you used Timken hubs -
if yes - bearings are not the problem -
2005 DeVille
makes it quieter
yes I replaced the cheap bearings with the Korean made timkens
