I have a 2005 CTS that started to overheat slightly today. I was driving home in 115 degree weather in Phoenix. When I got home I raised the hood and one of the electric fans was running, but the other was not. Is there ever a situation where one fan should run and the other does not? Is there any reason why one fan would not be running with the car slightly over correct temperature? Are there two separate electrical connections for the two fans, or only one? Any help is appreciated. Thanks.
2002 Eldorado Biarritz
Both fans either operate at low speed or high speed but, both together always. Check power at the questionable fan with a test light. But, it is probably a dud. If it is bad the other is likely not far behind it.
2007 6 speed manual tarnished platinum
I had one go bad too, tap the motor can with something or spin the fan with something (not your hand!) And mine would run a few minutes slowly then quit again.
