1 - 10 of 10 Posts
I hope this is in the correct forum.
I posted this over on PontiacBonnevilleClub.com and received no response, so....
I already ran two quarts of Techron (Advance Auto, buy one, get one free) through it a week ago.
There were no codes stored, as I have the Advance Auto clerk put a scanner on it.
The problem seems to get worse in the rain.
Also, I've had the "SES" light come on while going around corners, hard.
So, I started to unplug one coil at a time, starting with cylinder #2, in an attempt to isolate the problem.
As I got to cylinder #8 (front bank, closest to the dipstick) and pulled it, the engine shut off and will not restart.
:roll:
Any suggestions on rectifying the miss?
On getting the car restarted?
Thanks.
:dontknow:
2010 DTS
How do you unplug one coil at a time? Isn't the '05 COP ignition? The coils are inside the ignition cassette.
Ranger:
See picture on post #120.
That is the setup that I have. Eight individual coils, eight plug in connections:
181624-2005-deville-stumbles-8.html
I can't post a link here yet.
The OP's name is "HiPoint"
Thanks.
2000 Seville STS
First step: if you're seeing the SES light, go get your codes read, then come back with those codes. You're looking for codes P0301 (misfire cylinder #1) to P0308 (misfire cylinder #8). If you try to get the codes from the car using the instrument panel (possible in most Cadillacs, don't know about the Bonneville), you'll only get a P0300 (misfire, cylinder not specified).
You should be able to read stored codes from the built-in scanner with the key ON.
2010 DTS
I don't think you can. This is a Pontiac, not a Cadillac.
I guess they made some changes in '05 that I wasn't aware of. Never saw that coil set up before.
OK - '05. No internal scanner. You're right.............
The coil setup looks sort of like the Ford equivalent - a coil, connector boot, plug - all in one single assembly. You can literally replace one of anything without disturbing others.
1 - 10 of 10 Posts
