2005 Base Deville
This is the 3rd time for: After a hot restart the service tire monitor, air bag light, security light, traction control light all come on. In addition, the fuel gauge show no bars, the fuel average/range numbers missing. It runs and drives OK and a quick turn off and on doesn't change it. After sitting for an half hour or so, upon restart everything is back to normal. Anyone seen anything like that? Maybe a poor ground somewhere? It throws a lot of communication codes for all type of systems but clears on its own or I can erase codes. Not sure where dash ground might be...any suggestions would be appreciated!
2004 Deville
2004 Deville, Silver, Gone, but not forgotten, 1972 Eldorado, 1974 eldorado, 1975 CDV
Disconnect both cables from the battery and touch them together for a few seconds. this will reset all the modules in the car, it may help.
2003 Deville Base
be sure you disconnect the negative first, and reconnect it second. That may work, but I wouldn't rule out a bad ground somewhere.
