2004 Cadllac SRX AWD V8 Northstar
Having this issue with my wifes SRX. It starts fine when cold but when you drive it and stop for 15-45 min it has a long hard start but always starts. It has 60 psi on the fuel rail and holds after cutting off so its got fuel to the injectors. I have changed the Evap purge valve solenoid, changed all plugs, changed a bad 02 sensor, and checked all coils. Also have tried checking for vacuum leaks but no luck with that either. I get the same p0300 random misfire code and both p0420 p0430 catalytic conv. Please if anyone has any other tricks let me know.
2004 Cadillac SRX V8 AWD
sounds like maybe you want to check with replacing those converters, and depending on miles you should still be able to. I have an 04 4.6 as well, and the factory warranty is up July 2016, and 200k miles.
