I've checked all under hood fuses, all ok. Checked fuses under rear seat, only one blown is #14 Interior Lamp Dimmer Module, which I replaced but blows again, all other fuses look ok. Disconnect battery, reconnected, same issue, anyone know how to fix this issue. I haven't driven at in a while so do not know when it started. Cluster lights are working.
That's up to you.
An independent shop will be cheaper, but may or may not find the problem as quickly.
A dealer is pricier, may or may not find the problem quicker, but will most likely be less likely to damage any trim that needs to be removed to diagnose and repair it.
It all depends on the tech, and his/her resources.
