I have a couple questions -
WHEN did this problem start?
if it has been going on for a while -
is the fuse blowing quicker now?
does the fuse blow at ALL speeds - or just higher speeds?
how long does the fan run before the fuse blows?
immediately - 10 seconds - 5 minutes - etc -
could be several things -
debris in the blower cage causing a high power draw -
clogged cabin filter restricting air flow - causing high current draw -
worn out blower motor -
disconnected/clogged cooling tube at the blower motor -
bad ground resulting in high current draw -
there is a "common" ground hidden behind the passenger side kick panel -
Disconnect the connector at the blower motor and see if the fuse blows.
That'll tell you whether the problem is in the blower, or downstream.
