1 - 10 of 10 Posts
My Escalade leaks a lot of water when going through carwash. Passenger side it pours out under the glove box which in return wreaked the regulator for my fan. Not sure where it is coming from
2004 ESV
It's probably coming in via the cowl. It's not a terribly uncommon issue. When I was doing some research about the water coming in on the driver's side, I found some threads on other forums about passenger side water leaks.
2004 ESV
Is the floorboard under the carpet wet? Under the carpet is the drain line for the sunroof. In my case, my door molding was pressed in a little from being 15 years old. Replaced it, and had to cut a little V in the outer part of the trim so water would drain properly. I should replace the gutter rail between the top of the door and the roof. In the case of heavy rains, I can still get a little water to go over the inner door seal. But it would have to be a flood.
1 - 10 of 10 Posts
