1 - 2 of 2 Posts
PREVIOUS 00DTS,04DTS,04DTS,03CTS,07CTS CURRENT 07STS4 09CTS4
Hey guys, its been a long time I haven't posted on here I guess because everything has been well hope same for most of you.
about 2 weeks ago I started getting a "check gas cap" msg I tightened the cap and it still showed up then the SES light came on I pulled the codes and got a "PO496 - Evaporative Emission (EVAP) System Flow During Non-Purge" what does that exactly mean? lol
I checked the forums for this code didnt find anything....I'm guessing it just needs a new gas cap but just wanted to know if you guys think any different? I'm selling the car tomorrow afternoon so I need to figure out the problem.
Any help is always appreciated!
2020 XT4, 70 Cougar conv, 2002 DTS
If new gas cap doesn't fix it, check the EVAP purge valve on the back of the throttle-body. That valve is supposed to be closed at all times when the EVAP system is not purging, but it will leak if broken. You can take it off & try blowing air through it. If it allows air through it needs to be replaced. About $15 on eBay and elsewhere.
1 - 2 of 2 Posts
