Cadilllac DeVille 2004
I can't lock/unlock driver door using key or remote control (the lock knob is pressed, but the door is opened).
The other 3 doors(rear and front passenger) locks/unlocks without issues.
Looks like this problem appears after changing battery.
Any suggestions? Thank you very much for your reply!
2010 DTS
Re: Driver door is always unlocked, but the knob is pressed (Cadillac Deville 2004).
:welcome:
Time for some exploratory surgery. Pull the door panel and have a look see. You're bound to find something disconnected.
Tip:
When all the fasteners are pulled, the panel lifts off. DO NOT pull it off.
Thanks a lot! I'll try.
check for codes -
specifically DDM - Driver Door Module codes -
ALL switches on the driver door go through the DDM -
but you are probably in the market for a new power lock actuator -
check for codes -
The first thing, that i've made it was check the DDM codes.
There was only 1 CURRENT problem for DDM module --> DDM B3832, but its related with @window position sensor [email protected]
