1 - 8 of 8 Posts
2004 Deville base
Ok guys here goes,
Had a noisy leaking water pump, replaced it. Then found out I had a cracked tank in the radiator ,replaced it ! All was well for about a month. I should also state it has NEVER overheated, always right at dead center on gauge. Then started losing coolant but could not see from where,no drips. Yesterday it started leaking big time so I took the covers off and let it run. all of a sudden a good deal of coolant starts dripping from the firewall side of the motor but I can't see from the top or underneath where it is coming from. I fear a HG breach. Nothing in the oil, no overheating, nothing appears to be coming from the heater hoses. Any ideas are much appreciated. With 149k I'm not sure I'm up for 3 or 4 k in a head gasket repair. TIA, Joe v
2010 DTS
Sounds like the heater pipes that run along the rear head. PITA to replace.
98 Concours, 2004 Deville DTS
I know coolant pills aren’t really recommended anymore but here is my story. Last year I bought a 2004 deville DTS with 43000 miles on it. when I bought it I had 0 coolant leaked until I changed the coolant. All of a sudden big puddle of coolant under the car (Pretty sure it was from the crossover gaskets) I added the recomend amount of coolant pills and so far no more issues. Point being unless you know the history this might have happened to your vehicle as well. Just a thought.
Use the sealant tablets/power judiciously. It tends to clog small passages as well as the purge line and crossover nipple.
The coolant sealant tablets (Bar's Leaks # HDC or the equivalent powder G12BP) were totally discontinued by GM/Cadillac in 2006 or so. There are GM/Cadillac TSBs (Technical Service Bulletins) on this. The owner's manuals and radiator cover stickers were never updated.
His coolant leak - lots of it - is at the firewall area, right in the middle of the chronic Deville heater pipe failure area.
Homework -
2004 Deville base
Discussion Starter · #6 ·
Homework -
Exactly, Submariner! Is there a tutorial on this site that will give me a head start as to how to get to the leaking pipe? TIA.
Google something like "cadillac forums deville rusted heater piping". It's (unfortunately) been discussed quite a bit over the years.
Maybe OEM parts in either www.gmpartsgiant.com or www.gmpartsdirect.com.
Some have replaced the metal piping with heater hose but it's tricky and you have to be careful to not introduce any high spots (air lock bends) in the replacement hoses.
Check the surge tank and its closely associated fittings, Ts, and hoses. That lower coolant system sometimes leaks. Surge tank (reservoir) pictures in RockAuto.
2004 Deville base
Thank you , I will do so. Looking into replacing with heater hose,sounds promising.
1 - 8 of 8 Posts
