Sounds good thanks
Thanks a lot. Really helped. Good job with the pictures. Just to let you know I would have paid to get those steps
BTW it goes without saying to clean the pan with brake clean when you have it off and clean the pan magnet as good as you can. And if there are any gasket remnants on the pan edges to clean it with a very fine sand paper and brake clean too.
Also another pan specific item, I prefer the AC-Delco OEM pan gasket to the rubber style gaskets you might get with the filter.
Last time I did my trans fluid I ordered a WIX trans filter, it came with a rubber gasket, I was like nah, so I installed the WIX filter and I then ordered an AC Delco gasket that's like the original that came with the trans.
Both will work I just prefer the original style AC Delco aluminum + rubber gasket for the pans on the car.
Take it easy and enjoy.
