??? "resistor solution" ??? It's not a solution - it's the only way to fool the stability and body control systems when you delete the active F55 struts and shocks and simultaneously install passive units. The correct resistors simulate the electrical load of the active strut/shock - ~2 Ohm 10 Watt for F55 MRC; 4700 Ohm 1/2 Watt for the earlier F45 CVRSS systems. Different electrical loads = different resistor requirements.
The F45 and F55 body control systems receive inputs from over a dozen sensors and conditions - including roll, pitch, yaw, power level, vehicle speed, wheel speeds, braking action, steering wheel position, desired turn radius, actual turn radius, gear position, sideways acceleration, others. You need to either maintain the system to OEM high performance standards or fool it to get to a decent passive suspension level.
It's a far, far more sophisticated performance car than many people think, so you can't just throw BandAids at it and have one or two stick. Either restore it to OEM specs - or do the passive suspension conversion correctly, as per basscatt - or don't even try.
FWIW, The F55 MRC system uses a hydraulic fluid that has many millions of iron spheres suspended in it. The fluid transfer port through the piston contains a magnetic (solenoid) coil. The magnetic field around the port is varied as a function of body control signals - the fluid in the port area actually goes from 5W oil to thick jelly and back in less than .001 second, so it offers great damping control over strut/shock piston (suspension) movement.
The older F45 system uses differing port sizes to control oil flow inside the strut/shock.
Passive units are fixed flow - one damping setting and that's IT.
Roger, Just as an aside - when you first posted this in an Eldorado thread concerning F45 suspensions - The Eldorado, slated for extinction in 2002, never got any upgrades past 1999 except for the engine/transmission. So Eldorado (ETC) and Deville (DTS) never had the later F55 MRC suspension. Only the 2002.5 - 2003 - 2004 STS - Seville Touring Sedan, had it - and the only 2004 STS (274 built until December 2003) were all exported to Canada/Europe. (The 2006 and later "DTS" is NOT a Deville.)
