1 - 11 of 11 Posts
2003 STS
I bought this car used and the previous owner swapped out the air controlled struts with standard struts. I found the thread to use the resistors to "fool" the system and installed on the front struts however I can not find the wires to the rear struts. I don’t know if they cut them and tucked them in somewhere or what. Does anyone know where these would run from or if there is another place to wire in the resistors for the rear?
Our cars use front struts and rear shocks. None are "air controlled". The shocks incorporate air bladders as part of the Electronic Level Control which compensates for extra weight in the rear seat or trunk. ELC is NOT suspension control. The struts do not use any sort of air control.
Our suspension control is the Lord/DELPHI Magnetic Ride Control system (RPO F55).
The 5 Watt 2 Ohm power resistors are jumpered across each strut/shock wiring pigtail. The shock pigtails plug into the top center shaft of the shock.
Look carefully at the F55 suspension shocks in RockAuto - the top center shaft is protected (shipping) by a blue plastic cap in the pictures.
2003 STS
Thanks Submariner409 it's the pigtails for the rear shocks that are missing the only thing I see there is an airline.
(EDIT: Did you read Post #2 ? Sub.)
The electrical pigtails (as well as the top of the shock shaft) are inside the trunk. The wheelwell carpeting has to be removed.
The air lines connect to the upper side of the shock shell / body.
Wheelwell carpeting, side and upper - not the trunk (floor).
2003 STS
Discussion Starter #8
Thanks Submariner409 Found the pigtails and installed the resistors. The speed limited to 90 is now gone but still have the service suspension system flashing. I cleared all the codes and will drive a couple of days to see another code pops up. Is there something else I need to do?
2003 STS
Discussion Starter #9
I've cleared the codes a few times now and I'm still getting RSS C0625 which is the left rear position sensor. Is this the same as the pigtails in the trunk that i put the resistors on or something else?
clearing the codes does absolutely nothing -
other than erasing the code - temporarily - from the suspension module -
a "current" code will constantly be reset until the actual problem is fixed -
NO - it is a ride height sensor - your STS has 4 of them -
the left rear sensor is GM 25728489 - around $45 on ebay -
Here's your F55 MRC suspension height sensor - LR - check the connectors and link rods for all 4. Our suspension height sensors are also used for the rear ELC system.
1 - 11 of 11 Posts
