1 - 20 of 23 Posts
2003 Seville STS
Okay, so last Tuesday I went out to start my car at about 10 AM. It was considerably cold (about 31°F) and when i turned the key my car wouldn't start.... All I got was multiple rapid clicks and the headlights were flickering along with the clicks. The clicks were in about a 8-10 click sequence. And it would last maybe 3 seconds. Even if I turned the key in the off position. So I went and jumped it from the under the hood positive terminal thing. And it started right up. After that it ran fine. Until today. (5 days later) I went out with my girlfriend to grab some food about 4 miles from her house....When I came back, the car wouldn't start. It did the same exact thing. It would click rapidly and the lights would flicker with the clicks...... The weird thing is that every electrical thing worked. (Windows, radio, dic, inside lights, headlights, etc). After turning all electrical thing off, I tried starting it again and it still just clicked. I checked the battery voltage on the DIC and it read "9.4 ok"...now that seemed extremely low to me, because I thought it was supposed to be at about 12.4. Anyway. We called my girlfriends mom, and she came and I jumped my car and again it started right up. Now here is my question. If the battery was bad, wouldn't the car not even have the ability to power any of the lights or radio? And wouldn't the car not even click? So what could it be if its not the battery. And how can I find the source of the problem?
Oh today when it didn't start it was also 28°F. I don't know if that has any relevance
· Super Moderator
2010 DTS
Re: 2003 Seville Sts No start
It IS the battery. Replace it.
No, it has enough power to run lights and radio and operate the solenoid (that doesn't take much). The clicking you hear is the solenoid engaging the starter pinion with the flywheel ring gear, but it does not have the power to turn the motor over.
· Super Moderator
2010 DTS
Maybe, but it's not holding a charge. Batteries don't last forever and they rarely fail at an opportune time. Replace it while it's at YOUR convenience. It WILL fail again.
And don't try to cheap out. You NEED a series 79 battery with side vents as it is under the rear seat.
· Master of the Dark Art of Diagnostics
if you really have aspirations of some day becoming a REAL MECHANIC -
you should start by learning/reading/investigating on your own -
THEN verifying the information YOU gather by asking intelligent questions -
do an internet search "why do car batteries fail" - it will turn up a lot of good information -
here are two basic - but very informative articles well worth reading -
http://batteryuniversity.com/learn/article/what_causes_car_batteries_to_fail
http://www.batterystuff.com/kb/articles/battery-articles/battery-basics.html
2003 Seville STS
Okay. That's not to to bad. Thank you for the help Ranger!
Thanks for the tip. Becoming a Cadillac Mechanic is my goal. I want to open my own shop with my father when I get out of college, and specialize in Cadillacs. I do a ton of investigating and reading.... That's actually what I do with most my time. But for my situation from what I read on this forum I didn't think that it was normal for the battery to be dead, but still be able to power the lights and radio and stuff, so I just wanted to see what other people thought.
· Administrator
Use this - lead acid battery technology says that once the battery gets down to 12.0 - 11.8 volts there's some voltage there but not enough amperage available to start the engine.
............ it has to do with the sulfuric acid in the electrolyte turning to lead sulfate on the plates as the battery (chemically) produces electricity, and if the sulfate is not dissolved back into soultion by long charge times it hardens, gradually killing the battery. Thus the modern use of aftermarket battery maintainers in our high-demand cars.
If the battery is more than 5 years old, it's living on borrowed time, particularly in cold climates.
2003 Seville STS
Discussion Starter · #12 ·
UPDATE: Okay so. Today it wouldn't start again. So I ran it through the gears. And tried and it actually cranked a little but then started clicking. So I put it in neutral and and tried to start it and it fired up. Does this still seem like a bad battery?
2003 Seville STS
Discussion Starter · #14 ·
MoistCabbage said:
Just replace the known bad battery before you go looking for other problems.
I will. I need to get the money together for the battery. But is it abnormal that it wouldn't start but once I switched it in neutral it started? I just can't afford to spend $150 on a new battery if the one in it now is perfectly fine.
I will. I need to get the money together for the battery. But is it abnormal that it wouldn't start but once I switched it in neutral it started? I just can't afford to spend $150 on a new battery if the one in it now is perfectly fine.[/QUOTE---------------
so - take the battery in and have it load tested -
· Super Moderator
2010 DTS
If you want to prove the battery bad, just remove it and temporarily replace it with another one from your buddy's car. Hell, you don't even have to remove it. Just set the test battery next to it and touch the cables to the terminals. Then have someone start the car. Just don't jump it. Both cables come off your battery and go on the known good battery. You want your battery completely out of the equation.
2003 Seville STS
Discussion Starter · #17 ·
But isn't the battery in my car different than regular car batteries? If I'm correct I believe I read that it was a 79 Series? So if I were to do this I would have to track down someone with the same battery as mine? Or will any car battery work for this test?
03 STS
Well u do need a side post battery for ur test. The battery has hot on left and neg on right side and there are some batteries out there with reversed terminals so it might not fit in ur car. U need a fairly beefy battery. 600-800 cca or so? But almost any GM battery will work. I had a 78 series but swapped it out to my grand prix which uses a 74 series. The 74 is 1/2" narrower. Less less guts.
· Administrator
Wrong
. His car has the battery under the rear seat and the battery has a special cell top vent system which uses a tubing manifold and vent through a rubber grommet in the floor pan. It's a Group 79 side post battery of about 800 CCA.
His GM service manual says " ...... at least 770 CCA......." - AC Delco batteries are just fine, but in a pinch a battery from one of the 3 or 4 large manufacturers in the U.S will be OK.
1 - 20 of 23 Posts
