2003 STS best car EVER
I don't know if it has been raised as an issue before. I looked and didn't find it an archived related problem though the guy that had a heat problem might have been close. I never noticed a lack of heat in the car but the car could have been compensating from the passenger side or I was in layered clothing.
The noise was a higher pitched 'whir' left of the steering wheel and had a "belt" quality about it that seemed to be coming from the air vent. It would start immediately when I turned the engine over in cold weather and last for two or so minutes then stop once it was warmed up. It never happened on a sunny warm morning.
Well, I finally had my mechanic look at it after a few months when this started.
His diagnosis was a failed "Inside Air Temperature Sensor". The part was $98 and installed within an hour.
I'm hoping he was right... he has been in the past. Time will tell.
Just sharing.
The mechanic was correct. The bushing dries out and starts to squeal. Sometimes you can lube it and save it.
Posted in these forums many times - Google "cadillac forums seville cabin air temperature aspirator" or something close.
How-to's on muffin fan (computer board cooling fan, 12V) lubrication down in Cadillac Tech Tips - with pictures. The module is about $35 at a Cadillac dealer, a half hour cleanout and install IF the fan is frozen.
2003 STS w/BoseNav, 1993 Deville, 1985 Deville
I just 'refurbished' my Aspirator Fan (as GM calls it). It's been discussed on this forum quite a bit as Submariner says. Easy to replace/fix. I just took mine out, lubed the bearing with 10w-30 motor oil and reinstalled it.
yep - we get a bunch of these questions -
it usually happens after the first really cold snap -
then continues sporadically throughout the winter -
a drop of oil cures 90% of them -
I am keeping the mechanic. His staff called me after they serviced and and asked if I was happy with the work.
"More than happy I told them".
I didn't know I had bad air flow till I got some.
Defogging just became easier.
Cold snap?
What constitutes a cold snap to you?
I live in Winnipeg. My STS lives in Winnipeg. The car has to have heart to survive.
Cold snap?
Cold snap?
the little fan inside the aspirator
USUALLY squeals when the outside temp hits around ZERO for the first time -
then MOST of the DIY people who come here for a diagnosis
put a drop of oil on the fan bearing - and it's good for another 10 years -
the "electronics" part of the aspirator RARELY - if ever - fail -
the problem is the little fan that draws cabin air past the thermistor -
when this little fan gets covered with dust - or the bearing dries up -
the climate control system does not get an accurate cabin temperature reading -
so the system can't accurately adjust the temp -
