2003 Cadillac SLS 2014 Cadillac XTS LUXURY AWD
recently my Cad Seville was having problems running, dying and starting.
Replaced Cam sensor, then both upper and lower crankshaft sensors.
Now starting is taking longer and P 0335 comes up.
How do I resolve this, check wire looks good.
Fixed !
Re: 2003 Seville SLS PO 335 afterchanging sensors
hi there, The code P 0335 refers to lower crank shaft sensor; bad ground, bad sensor, I did replace sensor.
Fixed !
Did you replace BOTH sensors?
Did you check the connector & wire?
Yes, both Crankshaft sensors, check wire good, connector cleaned and does not look as straight as the connector to the upper connector.
