1 - 14 of 14 Posts
2003 Deville DHS, 2003 Seville SLS
Hello, Wife parked our '03 Seville SLS at our local McDonalds Tuesday evening and it would not start when she got ready to leave. I suspected battery but it checks out and seems to take a trickle charge and hold it. I removed the main ground wire from the battery and the chassis. Cleaned the Chassis connection and reassembled. Although the bolt there was rusty it seems to be making a decent connection for now. all the lights bells and dingers seem to be working fine. When I go to start it every thing on the dash shuts down (which I think is normal) as in lights out fuel guage goes to Empty but no starter noise. I can't tell if the solenoid is engaging or not. I swapped some of the likly relays with less pertanant ones around in the fuse block under the hood. I have not checked any connections; power or ground under the hood yet. Where should I look for the power line feeding into the engine block for the starter, I should have noticed but honestly I just was not looking for a starting under the intake so could have easily missed it.
Temps here have dipped to 8 degs F overnight. I would rather not tow this thing if I don't have too. I am no McGuiver but have been a fairly accomplished "shade tree* mechanic over the years. If anyone could help me with some specific info on this type of problem I would appreciate it. partial Codes listed below.
One more thing the car has been cutting out with erratic idle for several weeks. Not an actual miss but defiantly erratic. Low idle speed on cold start but smooth. After it warms up things get more interesting, usually get a rhythmic idle speed pulse from 600 to about 1200 rpms on about a 1 second cycle. Full out on the highway it growls nicely and not sign of a problem with varying RPMs I have replaced the downstream O2 sensor and I tried the TPS off an '03 Deville that I drive daily. Some of the idle speed issues have now shown up also in the Deville although I did swap the TPS back.
Any advise, suggestions or criticism welcome at this point. I am working so finding time to work on a car in the McDonalds parking lot is never easy or pleasant.
ABS: C1224 History (Air pump out)
ABS: C1225 History
ABS: C1228 History
ABS: C1232 History
ABS: C1235 History
ABS: C1287 History
DDM: ?3833 Current
DDM: U1713 Current
DDM: B1004 Current
DDM: B1652 Current
IRC: U1064 ??
IRC: U1016 ??
IRC: U1000 ??
PCM: P0101 ??
PCM: P0102 ??
PCM: P0171 ??
PCM: P0104 ??
RIM: B1007 ??
RIM: B1328 ??
RIM: U1255 ??
TTM: B1982 ??
TTM: U1016 ??
TTM: B2947 ??
2010 DTS
Codes are meaningless without definitions. No one has them memorized. Use the OBDII link in the DTC Sticky to find them.
Do you hear a clicking when you turn the key? What's your battery voltage? Doe the headlights go real dim when you try to start it?
Check your codes again. I do recognize P0171 and that is usually accompanied by P0174. I suspect that's what you meant instead of P0104. That would point to a ripped plenum duct (rubber coupler between the TB and the manifold).
P.S.
Clean the TB while you are replacing it.
Ranger, Thanks for reply. Lights did not dim while in crank position. Got car back home and tore into it. Starter was bad, would not bench test, all wiring and voltages good at starter. New Starter and intake seals ready but can not locate the plenum boot in stock anywhere (Sunday). Pressed a couple parts stores past the usual first try search and they did identify and confirm they can order it. Will likely be in for a couple days. Plan to check with the local dealer Monday AM or order it online if not it stock or way too high. I see the Dorman boot comes with intake runner seals for $25 or less. So I can take my intake seals back. Boot did appear to have a hole in it.
I will be cleaning the TB, never seen so much carbon gunk. What cleaners are recommended to use on the throttle body?
I cleared all the codes previously and since it hasn’t started since I will pull those again and research what they mean.
Thanks again!
98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
PCM: P0101 ??
PCM: P0102 ??
PCM: P0171 ??
PCM: P0104 ??
P0101, P0102, P0104 are cylinder misfires in respective cyinders 1 , 2, 4.
P0171 is a clean condition code.
It is quite possible that the plenum coupling for the intake manifold to be torn. Yet, in the grande scheme of things there is a vacuum leak causing the possible misfire codes in those cylinders along with the P0171.
Since the intake must be removed to access the starter, replacing the coupling and intake mainifold seals at this time would be a wise decision.
98eldo32v said:
PCM:p0101, P0102, P0104 are cylinder misfires in respective cyinders 1 , 2, 4.
No, they're MAF codes. P0301-P0308 are misfire codes.
Thanks MoistCabbage, you're correct on that one.
I have codes floating around in my head, now I'm starting to mix them up?!
Mass air flow codes are going to be a bit tricky to pin down. Usually there is a wiring problem, unplugged mass air flow or the unit is bad. I have rarelycome across a bad unit, but it does occur.
Discussion Starter #8
It is fixed - Plenum boot and runner seals replaced and cleaned the TB when I replaced the starter and it runs like a top. No check engine light at all after logging several trips and about 300 miles. Thanks for your advice. I had heard the intake seals could cause a lot of trouble but was hesitating to go there. I had already replaced the downstream O2 sensor. If the starter had not quit I might still be puttering around in a poorly running ride and perhaps worse, replacing perfectly good sensors.
MAF codes in the OP's 2003 Seville might well be due to an intake air duct leak at or after the divorced MAF. A common culprit is the intake air duct resonator - the kidney-shaped plastic thing on top of the convoluted intake duct. If that resonator is not securely clamped into the hole it sets all sorts of codes.
Here's his Seville engine air intake end with the resonator removed and the hole plugged.
What's the deal with the plenum boot and the tears in them?
I've changed like three since I've started dabbling in these engines. Anytime I see lean codes after checking all the obvious stuff, it leads to the plenum boot.
What is it? Bad design, poor installation? Every plenum boot to date is torn near the bottom?
Never go through the hassle of changing the plenum boot without chnaging the seals at the intake/head.
Better safe than sorry.
Glad you fixed it............
2010 DTS
If you look at the plenum duct you can see where liquid will settle in it. My guess is that once shut down, EGR & PCV gases condense and settle in the low spot in the plenum duct. Over the years, the acids deteriorate the rubber. I'm surprised that mine has lasted as long as it has.
That may explain it then.
The plenum coupling is basically "eaten" away until it causes a leak.
Well, I guess every couple of years you change the coupling and chalk it up as maintenance.......
2010 DTS
Well, I wouldn't go so far as to call it "eaten" away. As for the replacement schedule, like I said, mine has 10 years on it so far.
1 - 14 of 14 Posts
