Doesn't say in owners manual, on door, the bottom of the pan, and the VIN lookup produces two choices.
Very curious to know which filter to buy, as well as trans fluid capacity.
Premium Member
2004 Escalade 6.0
Look at the sticker in the glove box
2006 Escalade AWD w/DiabloSport tuner,Jet Performance throttle body/MAF,Airaid MIT
The Cadillac Escalade from 2002-2006 is equipped with the 4L65E HD transmission. Very reliable transmission if used with the high quality Dexron VI transmission fluid. A drain and fill with filter is usually about 4.5 quarts; and 4 quarts with only draining the fluid.
I would suggest swapping the original transmission pan for a 4L65E pan with a drain plug since the Escalade transmission does not come with a drain plug so that you can easily drain the old fluid every so often.
