I have an odd issue where I start my DeVille and everything is fine, but when I shift into reverse or drive right after starting my car will sometimes dip down into 400rpm ranges. As soon as I hit the gas pedal it seems to go away and I don't have the issue anymore. I have cleaned the TB, and replaced the TB sensor just in case. No changes.
Here are my current codes. I think one has to do with my fuel tank pressure sensor, and obviously the solenoid. But I'm unsure what the 02 sensor code means.
Car Scanner ELM OBD2
DTC report
Selected brand: Cadillac
============1==============
P00D9
Raw code: 00D9
ECU: 10
Status: Pending
============2==============
P2200
Raw code: 2200
ECU: 10
Status: Pending
OBDII: Nitrogen oxides (NOx) sensor, bank 1 - circuit malfunction
============3==============
P1860
Raw code: 1860
ECU: 10
Status: Pending
OBDII: TCC PWM Solenoid Circuit Electrical/ Transmission Transfer Case Contact Plate "D" Short Circuit To Battery
Cadillac: TCC PWM Solenoid Circuit Electrical
============4==============
P0741
Raw code: 0741
ECU: 10
Status: Pending
OBDII: Torque converter clutch (TCC) solenoid - performance or stuck off
============5==============
P0440
Raw code: 0440
ECU: 10
Status: Pending
OBDII: Evaporative emission (EVAP) system - malfunction
============6==============
P1860
Raw code: 1860
ECU: 10
Status: Confirmed
============7==============
P0741
Raw code: 0741
ECU: 10
Status: Confirmed
============8==============
P0440
Raw code: 0440
ECU: 10
Status: Confirmed
DTC report
P00D9
Raw code: 00D9
ECU: 10
Status: Pending
P2200
Raw code: 2200
ECU: 10
Status: Pending
P1860
Raw code: 1860
ECU: 10
Status: Pending
P0741
Raw code: 0741
ECU: 10
Status: Pending
P0440
Raw code: 0440
ECU: 10
Status: Pending
P1860
Raw code: 1860
ECU: 10
Status: Confirmed
P0741
Raw code: 0741
ECU: 10
Status: Confirmed
P0440
Raw code: 0440
ECU: 10
Status: Confirmed
