1 - 8 of 8 Posts
2003 Deville base
I recently replace my idle air control valve because I was having a problem with the RPM's jumping up since then the car is running great and in park rpms stay steady at 675 however sitting in park the car constantly shakes just a little bit I can feel it in the seat when I'm sitting in it it also does this when the car is stopped and In drive. it's not a huge problem but just wondering what this could be.
2003 Deville base
Haven't checked for vacuum leaks yet kinda not sure how to check.i did buy starter fluid just not sure where to spray it.as for the plugs I have had the car 2 years and it has 99k not sure when the last time was before that. it does start up fine everyone though.
2010 DTS
Spray the starter fluid around the plenum duct, particularly at the 6:00 position and flex it while spraying. Also at the PCV line where it plugs into the rear cam cover and anywhere else you see a vacuum line.
Yep - you get a slight idle speed increase - increased "fuel" sucked in at the vacuum leak point.
Find the plenum and clamp in this picture - same engine, different air intake ducting.
1 - 8 of 8 Posts
