1 - 16 of 16 Posts
2003 Deville base
Passed month or so I have noticed a red spot of fluid on my garage floor.about 1 drop a week.possible transmission or power steering?any commen places to look?I'm not low on any fluids as I've been checking daily now.
2004 Cadilac Deville Base, 90,000 mile
Re: 2003 cadillac deville red fluid leak
I have a 2004 Deville, which leaks something colored too {possibly red}. Haven't got to the bottom of it yet.
2003 Deville base
I have had a small oil leak from my pan gasket but this is definitely red not sure where it's from or what it is
the only red colored fluid is trans fluid -
2003 Deville base
Ok thanks I thought the power steering was also I'll have to check.where would be a good starting point to check for leaks
PS starts out clear - often turns brown -
directly above the drip on the floor?
1992 DeVille, 2013 ATS 3.6
like bass said. Maybe check the trans oil cooler lines. And the trans pan? Wipe it all down clean and keep an eye on it all to see if you notice any new moisture
2003 Deville base
Discussion Starter #8
it has not drip in about a month and then all the sudden the other day I started to get one or two drips a day when the car is parked in the garage I'm assuming its transmission fluid because it is red the drip is always in the same location in the center of the vehicle and about a foot behind the oil pan towards the back of the car not sure what's there it could be coming from
2003 Deville base
Discussion Starter #9
Also forgot to mention I'm not getting any codes and my fluid has trans fluid level is good .it also says 100 percent on my dash
2003 Deville Base
a foot behind the oil pan near the back is no where near the transmission. also, the DIC message of 100% has nothing to do with fluid level. Are you checking the tranny fluid level with transmission at operating temp, car on level ground, engine running and in park?
2003 Deville base
Discussion Starter #11
Yes I did check the trans fluid with the car running and it's fine.it hasn't leaked a lot just a drip or two a couple times a week.ive been keeping cardboard under the car to check for drips and everytime it drips it's always a drip mark directly (6inches) behind the oil pan towards the back of the car.its definitely a reddish color and not oil.
just keep in mind that the spot where it falls off the car -
is NOT necessarily where the leak is from -
2003 Deville base
Discussion Starter #13
ok thanks I have checked everywhere underneath the hood and cannot see any leaking from anything next step will be to get under the car any suggestions where I should look first
98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
First place to look is the left side axle seal....the fluid blows back as the car runs down the road.
Transmission line leaks, possible but highly unlikely.
and if you are that worried about a drip or two -
you can get the dye that fluoresces under a blacklight -
makes it real easy to find the source of the leak -
2003 Deville base
Discussion Starter #16
got under the car today it didn't leak at all today and I didn't see anything as far as where it would be coming from I'm just going to keep an eye on it I guess very strange
1 - 16 of 16 Posts
