2003 DeVille problems
1.1K views 9 replies 5 participants last post by  ELDORADO2K
I have a 2003 Deville(Base) and it started running rough 2 days ago. As soon as I start the car it’s idling low. I give it gas and when the rpm’s come down it will stall out on me. I pulled the codes and this is what I got:
IPC-B1004, B1438, U1000
IPM- B0429, B1004
PCM- p0506, p0621, p1189, B3832
RCC- B1009
RIM- C0660
SDM- B0041
Any help would be greatly appreciated
-Jordan
#4 ·
Wide open throttle can only be done with the car on.
Do a search for “WOT” on this forum. If you decide to do it, check your air filter 1st just to make sure it’s in good condition and not so bad that it’s actually the cause of your problem. Next make sure your oil level is full where it should be. And do it on a warm engine.
#6 ·
IPM- B0429, B1004
RCC- B1009
RIM- C0660
SDM- B0041
-Jordan
you probably need to clean the TB - Throttle Body and the IAC - Idle Air Control solenoid -
DON'T FORGET to clean the little air hole the IAC uses
#8 ·
yeah, that^^^ always post definitions. As for the WOT, you can't do it in park or neutral, because the computer limits you to 4000rpm. Find some deserted road, put it in low, stand on it and when you're almost at redline, let off the gas. If you see a puff of smoke out the exhaust, do it again. I do mine at least once a month. IIRC, redline on your base is 5900.
