1 - 10 of 10 Posts
2003 Cadillac Deville
I have a 2003 Cadillac Deville that is overheating. It seems like the only time it overheats is if it is idling on a hill, uphill. It doesnt when im stopped at a light or running or driving. I recently replaced the thermostat and it didnt fix the problem. I had the coolant flushed a few weeks ago so it has good coolant and is full. The fans do work but i have had alot of people say that maybe a relay or the temp sensor might be bad???? Anyone have any suggestions as to what to do next?? Also no leaks at al as far as i can tell.
Sounds normal to me................
Discussion Starter · #4 ·
Temp guage goes all the way up and then the intrument panel says a/c off and then that i need to idle car. so the temp guage tops out.
04 Deville, 11 DTS Premium, 00 Deville (sold), 02 Deville (sold)
I have a 2003 Cadillac Deville that is overheating..... I had the coolant flushed a few weeks ago so it has good coolant and is full.
Did you have an overheat problem before the cooling system was flushed a couple of weeks ago?
Discussion Starter · #6 ·
Yes it had done it before. I had refilled the coolant with water when it did the first time and that was part of the reason i had the radiator flushed.
2010 DTS
If it's going into the red and the cooling system is in good condition, you need to get a block test kit and check for exhaust gases in the surge tank.
If your overheating... then having to add coolant... then do as Ranger says and do the block test before spending any more money on the car.
2003 Deville
My 03 Deville is doing the same thing. Wondering what you did to fix the issue before I go broke trying to figure out what is wrong.
2010 DTS
:welcome:
Don't hold your breath waiting for an answer. 03caddyman hasn't been here since 03-30-11.
Do a search for overheating. LOTS of info on it. Start with the cheap and easy stuff, purge line, WP belt tensioner, surge tank cap.
1 - 10 of 10 Posts
