Noticed some oil on the driveway yesterday so jacked up the Deville to look for the leak. I found a slow like on the oil filter adapter at the bottom of the gasket
https://lh4.googleusercontent.com/-...AAAAAA-8/ye8FZfzrDjY/s800/20150206_150918.jpg
I also found some oil on this part of the engine. Not sure the name of that part but it was on the passenger side
https://lh5.googleusercontent.com/-...AAAAAA_c/_zXUF-0nDCs/s800/20150206_151041.jpg
While I us underneath the car I noticed green grease coming out of the CV Axle boot
https://lh4.googleusercontent.com/-...AAAAAA_0/VpRMQ6KNbbo/s800/20150206_151643.jpg
I already ordered a oil filter adapter gasket from amazon and also a oil sending switch.
I am not sure what to do about the other oil leak under the engine. Wondering if it can be fixed at home or if I have to take in to a shop
The CV Axle boot green grease is also something I am not sure about. I see they can be replaced with aftermarket Axles but If there is a way to rebuild this one I would like to fix it. There are times that I here a popping noise from the drivers side front wheel so I figured something was wrong there. I already replaced the wheel bearings and tie-rods on this car.
