2003 Deville
I'm going to replace the IAC valve on my 2003 Deville. It looks pretty simple. Unplug, remove 2 screws, and replace. Am I missing something or is that all it is?
WHY replace it? Cleaning is usually all it needs -
2003 Deville Base
^^^^what he said. I've only ever had to clean my IAC and throttle body and it runs/idles smooth as silk. But to answer your question, yes, it's that simple.
Remove it, clean the TB bore with cleaner and fuzzy pipe cleaners from a craft store, check that the IAC top hat plunger is screwed into the IAC body, clean that carefully. Should be good to go.
Why are you fooling with it anyway ?
IAC relearn - Key ON for 15 seconds, key off for 30. Start, let idle sequence ramp down, drive for 10 miles in the city/near suburban.
Normal cold start is 1200 rpm for 14 - 30 seconds, 900 for a while longer, 650 idle.
