1 - 8 of 8 Posts
81 supporter
replacing the batt in my 03 deville is there any thing i need to know other than yank it out and install new one??
i was thinking of hooking up a jumper pack under the hood at the jump points so i wont loose any preset info is this a good idea???
it must be the GROUP-79 battery -
I recommend the MAXX-79 from walmart -
you must re-use the vent assembly -
just be damn sure the POSITIVE battery cable doesn't touch ANYTHING
after you remove it from the battery -
REMEMBER - it will still be "live"
The only thing you should have to reset, assuming your driver memory buttons are set and the HU is on HOME presets, is the clock.
81 supporter
well i replaced the battery today and sure enough i lost my tire press sensors, it will only take me two or three weeks to reprogram them with a couple hundred tries , its funny cuz i only lost the left side sensors but not the right??
81 supporter
Discussion Starter #8
:hmm:
I find reprogramming them is easier when the weather is warm. Damned near impossible in the winter.
70 degrees today and i tried at least 20 times and only could get the front wheels to respond
1 - 8 of 8 Posts
