1 - 8 of 8 Posts
2003 Deville base
does anyone know a part number so I may order my airlines if maybe they come in a kit I am replacing my shocks in the rear as well as my compressor and would like to start fresh with all new lines
Not sure just getting rimco660 and my compressor is always coming on
Not sure just getting rimco660...................
HMMmmm -
GEE -
not absolutely sure -
but -
maybe -
just MAYBE -
the code DEFINITION -
MIGHT -
point you in the right direction -
to discover the reason
your compressor continues to run -
but - it's just a guess -
2003 deville
That code is for level control exhaust valve circuit malfunction. I'm getting that code and since I have my compressor isn't doing it's startup test. New lines new dryer new shocks and new rubber lines on older compressor. Which is about to be new soon too
97 DeVille
Have you considered replacing the level control exhaust valve? It sounds like you've replaced everything else and the problem still happens...
Or at least checking it to see if it works properly?
1 - 8 of 8 Posts
