2003 Cadillac Cts
I replaced a bad tire on the front passenger side and 3 hrs later, I get a traction control light and Engine Power Reduced on the display. When I try to clear it off,the car dies out. I never had this until I changed out that tire. Any suggestions?
If the new tire outside diameter is larger or smaller than the rest of the tires - more or less tire revolutions per mile - the wheel speed sensors will set fault codes and several limiters kick in. Maybe the wheel speed sensor for the new tire is disconnected.......
ABS, Stability, Traction Control, other systems are affected.
2003 Cadillac Cts
Thank u so much for reading and responding to my post. The tires I'm running now are bigger than the stock ones, thanks to the previous owner and I've been getting that size for the 3 yrs I've had it, usually replacing the two front at the same time but this time, I didn't, got one and then the other like a month or so apart. My father said heck, put ur old tire back on then, lol
