1 - 2 of 2 Posts
Discussion Starter #1 (Edited by Moderator)
Ok, so I have an 03’ cts with the boss setup, I bought the trim panel and antenna as I am going to run all my speakers from aftermarket amplifiers, I figured I’d delete my factory wire just use yellow turn on and power and ground. Now I removed the oem Bose amp, ran a yellow switched wire , power from the harness and a ground from the back dash panel. Now I cannot get my car to go into any gear, I have tcs, abs and exclamation on the cluster, but the car starts and runs better then it ever has. Color me confused!
Hahaha never mind! I didn’t hook up the ground in the trunk from Bose amp back up and as soon as I did it works again
Welcome to CF !!! I changed your thread title to be a bit more descriptive of your particular problem and solution - we ALL need "Help!".
1 - 2 of 2 Posts
