2003 Cadillac CTS
I have a 2003 Cadillac CTS with an engine leaking oil under the engine on the drivers side, i haven't got underneath to see where the leak is coming from but I'll do that next, but what should i be making sure of and checking in this process? please help!
2007 CTS 3.6 >128k miles
IMO the first step is to determine whether the oil is motor oil, ATF, or power steering fluid. Could be any of these, based on the location described in your post.
Mine ended being the radiator, I had coolant and transmission fluid leak out. The car wouldn't go in any gears either, but when I put it in reverse the backup lights came on and the doors locked. I was also low on power steering fluid. 2003 CTS Caddy <3
